Never mind I think I found out the problem. The mouse button seems to be dying ;(
I need to press harder in order to make it single click.
I know this seems strange, here's another solution. swap your left click to right click then your right click replace the G-shift button.
open the mouse and put oil on the microswitch and press it a bunch to work in the oil.
it fixed that problem with 2 of my buttons on my razer and fixed a non responsive button too.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
I always wanted to do that, the problem is I can't seem to find any screws on the mouse around.
Check under the Teflon pads and the label
you can buy new switches and replace it, and it will feel like new. :D
Ryzen 9 5900x | x570 TUF Gaming Pro Wifi | 32gb GSkill 4x8gb @3000mhz CL15 | ASUS Strix RX480 8gb | XFX 750W psu | Cosair H100i GTX | Fractal Design R5
Drop ENTR Halo True | Logitech G900 Choas Spectrum | Blue-Yeti | AKG k553 Pro
