Are My Components Able To Fit Into This Case?
My Case: Corsair - Carbide SPEC-06 ATX Mid Tower Case
My Build: https://uk.pcpartpicker.com/list/jRbbTB
  • CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor
  • CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler
  • Motherboard: MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard
  • Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory
  • Storage: SanDisk - SSD PLUS 480GB 2.5" Solid State Drive
  • Storage: Seagate - 2TB 3.5" 7200RPM Internal Hard Drive
  • Video Card: MSI - GeForce GTX 1080 8GB GAMING X 8G Video Card
  • Case: Corsair - Carbide SPEC-06 ATX Mid Tower Case
  • Power Supply: EVGA - SuperNOVA G3 (EU) 650W 80+ Gold Certified Fully-Modular ATX Power Supply
  • Case Fan: Thermaltake - Riing 12 RGB Triple Pack 40.6 CFM  120mm Fans
My Aims:
  • 1440p Gaming @144hz
  • Black/Red System
  • Future Proof
If I Can Fit All My Items Into This Case Then For The Future What Can't I Fit?
  • Another HDD?
  • Another SDD?
  • Another GPU?
Finally, Is This Case Easy To Build In, For An Inexperienced PC Builder?
Thanks
https://linustechtips.com/topic/962296-need-advice-for-first-build/
it is always easy to build into full-size case maybe you will not do a great work with cable management but it is only esthetics
13 minutes ago, DrakurDM said:
Future Proof
wait until tomorrow new nvida gpu are coming, other then that is fine
14 minutes ago, DrakurDM said:
1440p Gaming @144hz
i am not sure you would be able to reach it in every game with ultra details but if you lower the quality it is possible, maybe with a little of oc
also consider a 1080 ti if your budget allows it or you could go full master race and sli the 1080s, you should check the benchmarks for the games that you are interested in and see if a sli of 1080 is better than the 1080 ti
  • Another SDD?
you could go in raid 0 but it will not increase your gaming performance, maybe the launching times
everything will fit in the case
23 minutes ago, DrakurDM said:
Should be buying an i7 8700 non or an R5 1600/2600 instead of the 8600K
Nvidia announces new GPUs tomorrow.
