Soo about OS , when i get my NEW PC (HELL YEAH) i obviously need an OS but , i spent all my money on the system already and i saw many ways of getting free Windows 10, the No product key ways
What are the Goodies and badies of the no Product Key way , and i saw you can buy Code Keys of Ebay instead of like my retailer for like 150$-130$.
https://linustechtips.com/topic/961952-help-me/
Most keys on ebay are OEM keys, (the $10 ones) so the came from old computers. They seem to work, but I have no Idea if they work long-term.
 CPU: I9-7900X RAM: 64GB (16X4) DDR4-2933 GPU: RTX 3080 MOBO: ASUS X299 Deluxe PSU: Corsair RM850 SSD: ADATA XPG SX8200 PRO 1TB HDD: Seagate Barracuda 2TB Case: Corsair iCUE 465X Cooler: Corsair 280 AIO
https://linustechtips.com/topic/961952-help-me/#findComment-11659569
There are several ways that are not terribly legal but are very hard to get caught doing. Even if you were caught you could say that you were scammed and probably get away with a warning. If you are a business, you technically need a Pro license but I can think of a few that don't. Something you can do is try third-party websites like eBay or bonanza.com as you can usually find someone selling some on there that can deliver a license in a few hours. However, you can use Linux, or leave windows unactivated (biggest issue is the Activate Windows watermark present after 24 hours). I was able to use Windows 10 unactivated for several months and never cared until I got tired of the watermark and used a third-party seller to get a windows 10 pro license for $10 on bonanza.com.
https://linustechtips.com/topic/961952-help-me/#findComment-11659574
Currently using one in my personal computer. Biggest downside is no support from Microsoft (honestly you aren't missing much support)
https://linustechtips.com/topic/961952-help-me/#findComment-11659578
Just now, Randomguy123 said:
i know about that but does it still have all the features of security and updates ?
yupp my cheap friend uses it just fine and I'd know if he had any issues because he whines about everything (also just use a solid anti virus like the free version of bit defender).
https://linustechtips.com/topic/961952-help-me/#findComment-11659580
11 minutes ago, Randomguy123 said:
Got steam ?
I'm not allowed to offer you help on finding the legit place to download Microsoft Toolkit, which contains AutoKMS. Doing so would be against forum rules.
The legit one will show up in windows defender and must be allowed first, so it can be hard to tell what is legit, should you ever be so bold as to search for it.
https://linustechtips.com/topic/961952-help-me/#findComment-11659581
So far it has for me. I haven't updated it since spring creators update since it is not an often used computer. But on my main computer, I have had no issue for over a year.
https://linustechtips.com/topic/961952-help-me/#findComment-11659582
3 minutes ago, cflanders said:
It is there, I tried it once for lols on something incredibly basic and they . were basically useless
What OEM means in that whole story , and dont you think buying From ebay is fine ? i mean buying from a guy who has good rating and he has like tons of Products ?
Also if i use the 1 with the watermark will i still have updates of windows 10  ?
https://linustechtips.com/topic/961952-help-me/#findComment-11659614
Yes sirrr you still get updates
https://linustechtips.com/topic/961952-help-me/#findComment-11659622
Just now, Klwdie said:
basically I mean 15 usd and its gone but its up to you
Yeah thats the point its not a problem for me , xD i have like TF2 keys and i can sell them and get Windows for about 15 usd but you know for 10$ on bonanza.com and even less on ebay its pretty convincing ...
https://linustechtips.com/topic/961952-help-me/#findComment-11659640
would not recommend unless you want to be scammed
is this like scam for sure , orrrrrr chances , if i go to top rated 1 on ebay isnt that less chances of getting scammed ?
2. so i should get like for 10-15 from like SCDkeys/bonanza.com ?
https://linustechtips.com/topic/961952-help-me/#findComment-11659652
