PROBLEM WITH EXTERNAL HARDDRIVE
Solved by dfsdfgfkjsefoiqzemnd,
There could be so many things wrong. The drive completely not showing up could be as little as a software problem, but could also be a hardware failure of the drive itself.
Does it show up if you plug it into another PC or laptop? If not, I'd take the drive itself out of the external enclosure and put it in another enclosure first (assuming you have another one at hand).
If that still doesn't help, it's time to talk to professionals.
