USB C ports will only charge/power a laptop if the port is configured to accept input power.  Also, the USB C power adapter needs to be rated for however many watts the normal adapter puts out if the USB C port meets the previous requirement.
Also, AFAIK, USB C maxes out at 100w.  Most laptops with a dGPU need 130w+.
https://linustechtips.com/topic/961218-usb-c-charging/#findComment-11653312
On 8/16/2018 at 10:45 PM, danomicar said:
My work laptop runs off a dock thats connected with a single usb c connection. I would imagine all computers with usb c should be able to accept power?
This is not the case.  I have two laptops that will not accept power over USB-C.
https://linustechtips.com/topic/961218-usb-c-charging/#findComment-11664530
