So I’m moving into a new place for college with an Ethernet jack next to the desk. I’ve got my main rig, plex server, and a raspberry pi I’d like to run through a wired connection. I mean I could run the pi off the router, but the main rig and plex would like to keep in my bedroom away from my roommates. I’m unaware of how fast it is, but I’m assuming either 100mbps, 250, 400 or gigabit. The reason for the 4 options is because that’s what’s offered in the area from the local isp, so I’m not sure which it is.
So is there a splitter that I could plug into the main jack and run my rig and 1-2 more off of it?
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/960987-ethernet-splitter/
I'd roll a router if you want things in your own internal network.
A switch could work but you may get addresses that are accessible from the rest of the network.
Please for the love of god don't buy anything that says splitter on it.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11651465
So you just plug an Ethernet from the wall into the switch and then out from the switch to your stuff?
Main Rig
Plex Server WIP
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11651485
21 minutes ago, RedAV8R said:
Yep.
A Router will make things a bit more private for you, and won't run that much more.
Of course another option is getting more Ethernet ports on a pc and running a router in a VM.
I honestly have no idea how the network runs at my place. I’ll see Saturday, and can double check. I know my roommate said the router was garbage and I was like we could all pitch in a bit
Main Rig
Plex Server WIP
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11651573
I'd vote for router over a switch too.  If they have any sense, they will limit your port to only allowing one client anyway so a switch wouldn't work in that case.
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11651709
If you use a router, you will most likely be double NATing this could affect some applications/games. Using a switch is the simplest and cleanest setup. If you want to do actual routing you could set up a router w/o using NAT but that requires both the main router and your router having those options.
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11651754
Yeah I've got no  idea how it's setup. I'm not sure if I have to deal with the apartment people or go through the isp myself. I know move in date is the 18th, and one of the guys had renewed his lease and is in the place. He didn't seem very tech savvy when I asked him questions
Main Rig
Plex Server WIP
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11651947
Yes double NAT is not great, but as they already cannot access port forwarding and the alternative is risking every client on an unknown untrusted network (meaning you have to REALLY trust your client firewalls), I think its the safer option.
You don't necessarily need a router that supports access point mode to have it work as one.  So long as you can disable the DHCP server, it will naturally act as one on the LAN ports.  I have used various dumb ISP provided routers over the years like this.  The only potential pitfall is if it enforces client isolation.
But ultimately, I wouldn't fancy putting my clients on an unknown network without a router firewalling it from the clients.
https://linustechtips.com/topic/960987-ethernet-splitter/#findComment-11652103
