9 minutes ago, Darling300 said:
https://pcpartpicker.com/user/Darling76/saved/bcykdC
Hello, I was wanted to ask if there is anything worth upgrading in my current build.
Thank you
Dude that's an awesome pc. It wouldn't be financially beneficial to upgrade anything on that pc right now because it's really nice
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Thank you
I have that same processor overclocked to 4.5GHz on a Gigabyte GA-X99 Gaming G1 Wi-Fi board with cooling by Corsair H100i v2.  Only thing I would replace is your case with either the Fractal Design Meshify C or the Phanteks Enthoo Pro M TG. Both have better airflow than the Define S.
