Ok so I just finished building my PC (no os yet)
https://pcpartpicker.com/user/MARINE_TIGER/saved/trXbXL
Here's the issue motherboard only has 1 CPU fan header, case has a pwm fan controller that says to plug into the CPU fan header, so I did that.
CPU cooler(I believe it is the "fan" inside the pump(IDK though)) says to plug in it on CPU fan header
Looked around and found the pump fan header plugged CPU cooler into that.  Did I do it right?
https://linustechtips.com/topic/960213-need-help/
Well, first off. The cpu cooler should always be plugged into the cpu fan header. Hard to follow that wording lol
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/960213-need-help/#findComment-11644741
I would reverse that config. You would want to know if your cpu fan has gone bad. Plug the case fan controller into the pump fan header. And the cpu to the cpu.
https://linustechtips.com/topic/960213-need-help/#findComment-11644749
