I recently bought and xbox, and have my gaming pc aswell, and I want to try and mount both of them to a desk. I was thinking of using Ikea stuff because that is fairly cheap. I had the idea that I could buy a wall mount and mount the Xbox to the underside of the table, and buy a pull out drawer to mount the pc. My pc runs very quiet and cool, so heat isnt too much of a concern. What are your thoughts?
https://linustechtips.com/topic/959878-custom-desk-mount-pcxbox/
It's doable for the PC I would make sure the drawer is either just a sliding tray to allow for open airflow or to modify a closed drawer so there is no back and a wide open front front for airflow.
As for the Xbox as long as your not covering up the vents up against the bottom of the desk it should be fine. Something like 3M dual Lock would work well for that.
