Hey guys! I Am soon going to build my own ryzen 3 2200g pc and I have a led strip still laying around, because I have a budget build, I rather wanna re-use my led strip, can I somehow get it in without too obvious cables or case modding? The motherboard I am getting is: Asrock Ab350m Pro4. The case is: Sharkoon V1000 Window. The led strip has a USb adapter. Thanks in advance!
I LIKE TURTLES
https://linustechtips.com/topic/959361-led-strip-in-pc/
Depends on your level of wiring if you are capable of stripping a molex psu cable and soldering it to your usb wiring
But if not you can buy this:
Option 1:
https://www.amazon.ca/USB-4-Pin-Molex-Power-Cable/dp/B01D4ZOXEG (USB to female molex)
and
https://www.amazon.com/Pin-Molex-Male-Power-Cable/dp/B00478TT1C (Male molex to male molex)
and plug it into your PSU.
BUT it isn't really economically feesible when you can buy the actual RGB with IR remote internal strip for cheaper
Option 2:
https://www.amazon.ca/Super-Bright-Computer-LED-Strip/dp/B01AZ4XX0E/ref=sr_1_5?s=electronics&ie=UTF8&qid=1534135206&sr=1-5&keywords=rgb+led+strip  (Plug this led strip into a sata power and control it with a remote. Comes with 2 RGB strips....can dance to your music and cause seizures or whatever else rocks your boat)
https://linustechtips.com/topic/959361-led-strip-in-pc/#findComment-11638856
