2 minutes ago, Vented_Swing_6295 said:
i dont really have a budget 60 fps or higher nvidia
Acer Predator XB271HK 27" 4K UHD IPS NVIDIA G-Sync Black/Red Gaming Monitor, 3840 x 2160 (4K), 100% sRGB Color accuracy, Tilt/Swivel/Pivot/Height Adjustable, Build in Speakers
https://www.newegg.com/Product/Product.aspx?Item=N82E16824009890
I have the 2k version of this- it's wonderful. The bezels are super thin and recessed so it looks very clean. The stand could use some work, so I'd suggest a desk clamp stand like this one: https://www.newegg.com/Product/Product.aspx?Item=9SIA4FH1SK8899&cm_re=clamp_monitor_stand-_-9SIA4FH1SK8899-_-Product
https://linustechtips.com/topic/957324-please-help/#findComment-11620296
https://www.amazon.com/PG27AQ-3840x2160-G-SYNC-Gaming-Monitor/dp/B01AWGY9MG
This probably, it's 4K with G-SYNC and if you can mount it, it'll become aesthetically pleasing.
I don't really like ROG designs but their Monitors are pretty dope.
https://linustechtips.com/topic/957324-please-help/#findComment-11620298
