My First PC Build
Go to solution Solved by Streetguru,
Just now, Fraser.C said:
Thanks i added a Seagate - 600 Series 240GB 2.5" Ssd, would what give me the StoreMI?
Going with Ryzen and B450 gets you StoreMI, which is really useful technology for hard drive acceleration.
Here's a more indepth video on the tech
Hi, This will be my first build and I Am just wanting to see if this will be able to handle most game at medium settings at least, I have a budget of
£800 and would like to buy most things from Amazon.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  (£152.03 @ Amazon UK)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£26.69 @ Amazon UK)
Motherboard: MSI - B360 GAMING PLUS ATX LGA1151 Motherboard  (£95.45 @ Amazon UK)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory  (£90.14 @ Amazon UK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£52.97 @ Amazon UK)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  (£165.21 @ Amazon UK)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  (£41.02 @ Amazon UK)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£47.99 @ Amazon UK)
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Wireless Network Adapter: Asus - PCE-N15 PCI-Express x1 802.11b/g/n Wi-Fi Adapter  (£16.08 @ Amazon UK)
Total: £687.58
https://uk.pcpartpicker.com/list/sGPPgw
Thank you in advance.
https://linustechtips.com/topic/957161-my-first-pc-build/
You dont seem to have an SSD in there, which I would recommend for the OS.
Just look for an SSD with about 120 Gb, that should be enough for the OS and a few other programs etc.
EDIT:
You could get a 250gb SAMSUNG 970 M.2 for about 100$.
There also are cheaper options like Kingston.
https://linustechtips.com/topic/957161-my-first-pc-build/#findComment-11618698
EDIT:
Ok Thanks I will look into one.
https://linustechtips.com/topic/957161-my-first-pc-build/#findComment-11618714
20 minutes ago, Fraser.C said:
a Ryzen 5 2600 is likely a better value CPU
You can easily get 50+% better GPU
Should buy a case that actually has airflow
wouldn't suggest the 2015 CXM model at this point
Buy a wireless adapter with an antenna you can move
And ya just add a 240GB SSD, though for B450 you get StoreMI, which means you can use up to a 128GB SSD I think, to accelerate your 2TB hard drive
PCPartPicker part list: https://uk.pcpartpicker.com/list/wDwxbX
Price breakdown by merchant: https://uk.pcpartpicker.com/list/wDwxbX/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  (£148.79 @ Aria PC)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  (£76.58 @ Ebuyer)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory  (£80.28 @ CCL Computers)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£51.59 @ Aria PC)
Video Card: XFX - Radeon RX 580 8GB GTS Black Core Edition Video Card  (£225.90 @ Amazon UK)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  (£43.79 @ Aria PC)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£52.94 @ Box Limited)
Wireless Network Adapter: Asus - PCE-AC55BT B1 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  (£31.99 @ Amazon UK)
Total: £711.86
https://linustechtips.com/topic/957161-my-first-pc-build/#findComment-11618727
Total: £711.86
https://linustechtips.com/topic/957161-my-first-pc-build/#findComment-11618745
https://linustechtips.com/topic/957161-my-first-pc-build/#findComment-11618750
