First off I had my first post for my psu and this forum in general was very helpful so thank you. Now I need help confirming whether my custom water loop would be okay to use since i know you’re not supposed to mix metals and all that.
I plan on buying to cool my cpu i78700k overclocked and in the future i plan on cooling a 1080ti i know ill probably have to add another radiator if i want to do this. My case can pretty much fit any radiator size i know of.
ek radiator: https://www.ekwb.com/shop/ek-coolstream-ce-420-triple
ek monoblock: https://www.ekwb.com/shop/ek-fb-asus-m9h-monoblock-nickel
still deciding on a pump/res from ek (so if u dnt mine helping choose a solid one it would be appareciated!)
primochill tubing and fittings(soft tube for now: https://www.primochill.com/collections/flex-fitting-bundles/products/primochill-lrt-fsx-tubing-and-fittings-kit-1-2in-id-x-3-4in-od-crystal-clear-dark-nickel
https://linustechtips.com/topic/956953-help-confirming-my-custom-water-loop/
That looks pretty good, something like this would be a good pump combo unit, as for your GPU block you will need to make sure there is a compatible waterblock for that specific model. As for raditor space you will have more than enough even with just a single 420mm for both the GPU and CPU.
https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
