I want to thank you guys for your replies on my post earlier...it really helped. But i found a guy who wants to sell a single stick ddr2 4Gb @800ghz ram for $5 but his motherboard is an AMD motherboard n am using a Dell Optiplex 760 C2D E7200 ...... Will it work????
https://linustechtips.com/topic/956637-need-help/
RAM isn't system specific like that. Only first gen, first wave boards have risk that RAM doesn't work. Bigger issue is that your mobo doesn't like mixing different RAM clocks, sizes and timings. So what RAM you have now?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/956637-need-help/#findComment-11616060
I currently have 1Gb (1x3) ddr2 @800ghz
https://linustechtips.com/topic/956637-need-help/#findComment-11618733
How many RAM slots mobo has? I can get specs saying that max amount of RAM is 8gb, but doesn't say how many slots there are (and Google image search gives 2 variations of that board). If you have 4 slots, then you it most likely doesn't support 4gb stick per slot. If it has 2 slots, it might support 4gb sticks. But I'm not sure.
https://linustechtips.com/topic/956637-need-help/#findComment-11618744
Yeah.....max amount of 8gb RAM and it has  4 slots.... I just made some findings and it doesn't support 4gb single stick but a 2gb single stick should work fine
https://linustechtips.com/topic/956637-need-help/#findComment-11619136
