Yesterday I hooked my PC up to my router, via Ethernet cable, and the problem I am having is that when i put my PC to sleep, it will wake back up before my monitor can even turn off. I know this problem is being caused by the Ethernet, because I unplugged it and the PC remained asleep. I have gone into device manager and turned off the "allow this device to wake you PC option off." The computer will remain off if I shut it down, the problem only happens when the Ethernet cable is plugged in and I put the computer to sleep. Any recommendations would be greatly appreciated.
https://linustechtips.com/topic/956527-help-needed/
Check and see if "Wake on LAN" or anything similarly named is enabled in your BIOS. If so, disable it.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/956527-help-needed/#findComment-11613392
