I've been looking into AIO's specifically for liquid cooling my GPU, however I am a fan (no pun intended) of max air flow as well. I am worried that most AIO's will restrict airflow significantly, do they?
As such, I would like an AIO with a radiator that has about 16 FPI. The main issue is that many AIO's do not list their FPI (Fins per Inch) in their specs.
I have found on EKWB, they do list specs of their radiators, and they have a series that has low FPI for what I need.
The issue becomes then - there isn't exactly any (or any that I can find) pump/res combo units which come with AIO's that are sold separately for this purpose.
I'm left to wonder, do I just need to buy a full AIO for this piece specifically, costing upwards of $100, then have to spend another $100 -/+ on the radiator I want to use?
OR should I just stop playing games because all of this is pointless, and just install a custom loop?
The issue there is obviously I wanted to do this cheaply, not to mention I have a gtx 1060 - I just wanted a simple solution to get lower temps under loan AND not restrict airflow as my CPU will remain heatsinked.
CPU: Intel i5-9600k | MoBo: Gigabyte Aorus Elite z390 | RAM: 16gb (4 x 4gb) Crucial Ballistix Sport LT DDR4-2400
GPU: Gigabyte Aorus Xtreme 1080ti | Storage: 500gb Samsung 860 vNand SSD x2 & 1tb WD Caviar Blue HDD
Chassis: NZXT h700i White w/ RGB LED | Cooling: Corsair H100i Pro RGB AIO & 6x Corsair AF120 fans White LED
Screens: 2x 27" Acer HA270 Ultra Slim LED | Peripherals: MSI Interceptor RGB DS4200 Key & D200 Mouse
https://linustechtips.com/topic/956041-building-a-custom-aio/
"custom AIO' is an oxymoron, don't bother just air cool
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/956041-building-a-custom-aio/#findComment-11609381
OK, a "closed loop" or "semi-open" loop or a modular unit..... semantics, you know what I mean.
https://linustechtips.com/topic/956041-building-a-custom-aio/#findComment-11609417
Still whatever, that D15 will perform like the best 240mm AIOs
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/956041-building-a-custom-aio/#findComment-11609421
