Hey guys! I have $500 to buy a new CPU, motherboard, and GPU to upgrade my rig. PSU and SSD are still fairly new, and I love my PC case. I run a Youtube gaming channel, so gaming and video editing are what this will be primarily for. I was thinking of going with Ryzen because of its productivity power, but which processor, I don't know, and I'm looking at a used GTX 980 for solid 1080p performance on a budget.
https://linustechtips.com/topic/955675-help-me-select-components/
5 minutes ago, JuniperRising_YT said:
I currently have a phenom ii x945 with 8 Gb of ddr2 RAM and two HD 5750 video cards in crossfire. I just threw in a 120gb boot SSD along with my 1tb HDD.
i5 8400 or i7 8700+16gb of ram if you're using adobe for editing/rendering.
So this is just slightly over budget, but the RX580 performs pretty similarly to a 980, but does support freesync if you snag a freesync monitor. All new components. Motherboard is a 3+3 phase that looks like a 6+3 phase(if it had a different controller it could and possibly would be a 6 phase, but the controller it has tops it at 4 phase so they run it as a 3+3 phase), and it should be cool enough even if you overclock the 1600. the DDR4 is 3000 Mhz which your Ryzen will love. it's exactly $20.75 over budget at the current moment.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($59.89 @ OutletPC)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory  ($80.88 @ OutletPC)
Video Card: MSI - Radeon RX 580 8GB ARMOR OC Video Card  ($229.99 @ Newegg)
Total: $520.75
Generated by PCPartPicker 2018-08-04 01:42 EDT-0400
Rawr.
