I just bought a new SSD from Kingston (Kingston HyperX 3k 120gb). I bought it to upgrade my old laptop's HDD which is starting to fail. I was looking on their website to see all the features and I noticed something called S.M.A.R.T? What exactly are the benefits of S.M.A.R.T? Can anyone explain?
The best way to predict the future is to invent it
https://linustechtips.com/topic/95559-what-is-smart/
https://linustechtips.com/topic/95559-what-is-smart/#findComment-1279292
SSDs will remap bad flash blocks to extra flash blocks if it fails. Eventually you will run out of flash blocks and all your data will be gone forever. S.M.A.R.T is used for monitoring that and remind you to replace the drive before it fails. It is used on both HDDs and SSDs.
Intel Core i5 3570K@4.5GHz | ASRock Z77 Extreme4 | 2*TEAM 8GB DDR3-1600@CL9-9-9-27 | Inno3D GTX 660 HerculeZ 2000s@1200MHz Core 6600MHz Memory | Seagate Barracuda 2TB | Antec Kühler H2O 620 | Antec HCG-620 | CoolerMaster Elite 371
Acer Iconia W700: Intel Core i5 3337U | 4GB DDR3 | 120GB SSD | 11.6" 1080p Display
https://linustechtips.com/topic/95559-what-is-smart/#findComment-1279314
Dooes it require 3rd party software?
Yes. You can use this. Install and run it. Select the drive, go to Device -> VIew details -> Attributes.
For more details, read this.
https://linustechtips.com/topic/95559-what-is-smart/#findComment-1279440
