eyefinity problem
Go to solution Solved by sulvaat,
I have this same setup and problem before. It's caused by CCC arranging your monitors for you after you enable eyefinity.
It boils down to one fix: It's a pain in the butt but once you set it this way you won't have any problems.
Under "Creating and Arranging Desktops" in CCC, make sure your monitors are labeled 1 2 3 from left to right with primary on 2.
Now set your wallpaper.
Then Physically rearrange your monitors so that your desktop wallpaper looks right.
It helps to label your monitor's cables with a little piece of tape or something.This will  ensure proper setup again if you have to move the machine.
so i have a triple monitor setup and want to use the wallpapers that span across 3 screens but when i apply them they are in the wrong order as soon a i setup eyefinity its fine but the problem is  when in extend mode can some one help ??
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/95558-eyefinity-problem/
Setting the wallpaper to "tile" within Windows (right-click on desktop > personalize > desktop background) can help me sometimes.
yea thats what you have to do but the problem is where the wallpaper is in the wrong order the only ways i can fix it is by changing my prime monitor to the right one i was wondering if there is a fix
PC PART PICKER
https://linustechtips.com/topic/95558-eyefinity-problem/#findComment-1279306
https://linustechtips.com/topic/95558-eyefinity-problem/#findComment-1279819
