Hey,
So, Ive been messing around with undervolting my New laptop, testing some things while using ThottleStop.
And was told to check to see if I'm getting the full boost clock speeds.
The CPU in the Laptop is the: i7-8750h.
I don't really need the crazy top speeds that the laptop produces, due to I'm never doing anything that is that CPU instinctive, I do however play games on it, It has a 1050ti, But I also dont play any crazy AAA Titles on it, or if I do I lock it at 60fps with Low/Med settings,  I dont mind having lower graphics also keeps the fan notice down a noticeable amount.
But my current Undervolt is -140mV on both the Core / Cache.. But while doing a Cinibench Test the max I was seing was 3.9 GHz on the Speed, Is that a problem?
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/955232-laptop-undervolting-help/
Nah, it's fine. Your CPU has a base clock of 2.2Ghz with a turbo up to 4.1Ghz. Since you undervolted it only boosted up to 3.9. Further decreasing voltage may yield even less turbo clock. Or... you could (im hating myself for suggesting this) disable turbo boost in BIOS. Your PC will get only up to 2.2Ghz which is not ideal for gaming, but since your concern is more on the noise part then you may find the trade off more apealing than me for sure.
Cheers!
ps: there is no risk involved in disabling turbo boost, it can be re enabled in the same way.
Cheers!
Hey!
Thanks for the reply, Yea. So I got it down to -160... But was noticing cinninbechin only geting to 1230 score, But when I set it back to -150 I was geting 1260.. So I left it at that, And still geting the 3.9 Speeds, But yea The noice isnt that bad.. Cant notice it while in school or anyrhing
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
