I have a case(forgot the name) that supports 5 fans. 2 are being used for my radiator and the other 3 are installed. I have one in the back and two in the front. The reason im asking is because my gpu is getting ver hot lately(85C) and I kinda need to fix it. If anyone has ideas on how i can increase airflow that would help. i also have an aio so no cooler is blocking air. Thanks
https://linustechtips.com/topic/954928-best-fan-setup/
Do you have your fans setup in a way where optimal airflow can be carried throughout the case?
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599651
2 in the front, 1 in the back is the normal setup for most peoples cases, Make sure the fans are running the correct way...That is a common issue.
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599699
3 hours ago, VinZie said:
Sure, if you are able too, point arrows where air is coming out
1 intake (back) and 2 exhausts (front) THE ARROWS SHOULD BE FLIPPED
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599711
Thats the wrong way around man.
You want the front to be sucking in air, While the back to be blowing it out..
And put 2 fans in the front of the case, and one fan at the back of the case, near the top, due to hot air going up.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599716
35 minutes ago, Hntercullion said:
Does your case actually have mesh or is it all sealed off? What's the actual name of it?
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599724
My bad I wasn't thinking straight.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599735
9 minutes ago, Hntercullion said:
not sure the exact name (if you know a way to find it tell me...). But I have mesh near all fans (see top left)
Just take a picture of the entire case and it can probably be figured out quickly.
But ya if your front 2 fans broke or the motherboard/ w/e isn't powering them that's probably an issue.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11599755
theres already a picture in the post, Just that the arrows are pointing the wrong direction.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600240
The outside of the case
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600272
what side?
Anything that has a full view of the entire case, not just the inside .
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600368
Just now, Hntercullion said:
That's probably a Define 2/4/6
And the front of your case has limited airflow for intake, which is probably why your temps are higher than average.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600386
do you think maybe its time to upgrade my case?
Unless you want to swap over to some high airflow case like an H500
just take off the front panel of the case, or leave the side panel off to get better airflow. If it's a define case the front panel has a door that can be opened for airflow.
If you're only having tempature issues recently it could just be dust, or your need to repaste your GPU, or it's just pulling more voltage for whatever reason.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600393
well i just cleaned every piece of dust from my case lol. I was thinking it was the gpu paste but that wouldnt explain the high cpu temps as well.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600400
Didn't you mention that both of your front fans were off/broken/not spinning?
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600402
ya i fixed them, Im getting like 78C now under load instead of 84C so thats an improvement but still..
Then just go for the high airflow option then, H500 is probably the best bet there
The RL06 Pro is also great, but has more limited AIO mounting options I think vs the H500
Or just open the case it'll probably be pretty close.
https://linustechtips.com/topic/954928-best-fan-setup/#findComment-11600409
