parts aren't cheap. If you have a scrapyard near you, you can get some cheap parts, They sell by weight so you can get things like a motherboard, CPU, ram, SSD/HDD, etc. However, the scrapyard has a lot of old junk so you have to part out the good stuff from the bad stuff, and some of it might not work.
https://linustechtips.com/topic/954909-i-need-help/#findComment-11599492
That is an extremely tight budget for a gaming PC. The way I would go is find a non-proprietary prebuilt with a capable CPU such as an i5-2500 and buy a used GTX 1050 Ti.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/954909-i-need-help/#findComment-11599496
3 minutes ago, Matija123 said:
There is no scarpyards where I live, so...
GT 1030 GDDR5 perhaps? Pushing even further, GT 740, GT 730, GT 640? I don't know much AMD cards.
https://linustechtips.com/topic/954909-i-need-help/#findComment-11599542
38 minutes ago, Matija123 said:
I am trying to build a 200/250 dollar ,,Gaming,, PC, I would use second hand parts...What are yours suggsetions?
You can't. Your best case scenario would be an amd ryzen 2200g. This means you have 150 dollars left to buy a case, ram, hdd, motherboard, and power supply with. It can't be done.
Sudo make me a sandwich
https://linustechtips.com/topic/954909-i-need-help/#findComment-11599605
