Fan headers
Go to solution Solved by Mick Naughty,
1 minute ago, Altruist said:
If i were to tell you my motherboard, would you waste time helping me?
If so Asus rog b360-g
I’m gonna go ahead and say Asus suite. Would be on the disk it came with. Along with on the site under that board support and downloads.
Are they Molex (shown below) or standard 3-pin/4-pin? 3-pin is compatible with 4-pin connectors. If it's molex, you'd need to use a  PSU adapter or a different cable if your PSU is modular.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/954562-fan-headers/#findComment-11596215
not molex, 3 pin look like pwm but with 1 pin missing
are the compactable?
I may be wrong.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11596221
Yeah, you can put a 3-pin onto a 4-pin connection, you just won't be able to control the fan through bios because of a lack of the fourth pin.
Just make sure the slot lines up when you put it in. Everything should be fine.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11596228
:D and the forth pin is pwm?
And thanks.
I may be wrong.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11597453
They just plug in like normal. I tend to always use my mobo software to control fans. Bios never does a good job of that for me.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11597555
1 hour ago, Altruist said:
So i can still software control them?
 Yea, don’t see why you wouldn’t be able to.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11597953
The one for your mobo normally. Or speedfan if you can learn how to use it.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11598968
Also nzxt cam if it’s actually usable by now.
https://linustechtips.com/topic/954562-fan-headers/#findComment-11598973
https://linustechtips.com/topic/954562-fan-headers/#findComment-11598981
