Sadly no (unless you do some sawing and case destroying). These Optiplexes are small form factor machines so you would need to go for a SFF graphics card. Probably best to simply sell the GPU you have on hand and try looking for a SFF one. These usually include "low profile" (LP) or "small form factor" (SFF) in their names.
For the 750ti specifically I know that there are gigabyte and MSI version of it. You might also want to look at GT 1030 as these are meant for office PCs and can probably be found in SFF easily and their performance is practically on the level of a 750ti.
Laptop - Omen 15
i5-7300HQ, GTX 1060 maxQ 6gb, 120hz Panel, 16GB DDR4 Ram @2400hz
Blue Box
i5 - 3350p, R9 Nano Fury 4GB HBM, 8gb DDR3 Ram @1600hz
https://linustechtips.com/topic/954374-help-with-gpu-upgrade/#findComment-11594694
You need a DIY solution. LTT style
Desktop benching:
https://linustechtips.com/topic/954374-help-with-gpu-upgrade/#findComment-11594720
