4 minutes ago, zero80472 said:
Good Build But iv made 2 change's that are better + cheaper
https://au.pcpartpicker.com/list/p8rYQZ
iv added a i5 8600k and a compatable motherboard ,
your saving at least $100,
Im trying to get it even cheaper, is there a way to lower my graphic card price / switch it out for another cheaper option without really affecting performance? Because i know i can overclock the cpu anyway https://au.pcpartpicker.com/user/Its_Joshua_S/saved/3WdNnQ
updated build
My PC Currently Is The P2-1320a.
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11593976
@ItsJoshuaS What games do you plan on playing, and what kind of graphics do you want? (EG LOW MED HIGH ULTRA)
        Current PC
CPU: I5-7400
GPU: Gigabyte 1050Ti
RAM: Crucial DDR4 8GB 2133mhz
CASE: GameMax Falcon
MOBO: Prime B250M-A
                                       Peripherals
Mouse: Corsair Sabre
Keyboard: Corsair Strafe
Mic/headphone: Blue Yeti /w JVC HA-SR50X
Mouse Mat: Razer Goliathus
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11594019
Most likely cod, fortnite with friends, Gta V, and using unreal engine and in the future using vr with oculus rift. I dont think i need a overkill graphics card so what would be the best pick? I also live in australia so there is that pricing
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11594030
@ItsJoshuaS I see no problem's, I think this could last a while maybe 3-4 years worth. I would go for a 1080 its 50$ more as well as a i7-8700k if you have the money as It's a lead processor for gaming at the moment. I have finished building mine all I have to do is save up money. My build consists of a1080ti, i7-8700k ,16gb ram and its expected to play 3-5 years of high-ultra in games. With that in mind the new GPU's are coming out soon, so maybe wait to see if prices drop.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11594036
So i made some changes to my build, https://au.pcpartpicker.com/user/Its_Joshua_S/saved/3WdNnQ ? is it good?
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11596569
made some changes, this is much better:
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($518.00 @ Shopping Express)
CPU Cooler: Scythe - SCNJ-4000 84.6 CFM CPU Cooler  ($66.20 @ Amazon Australia)
Motherboard: ASRock - Fatal1ty Z370 Gaming K6 ATX LGA1151 Motherboard  ($229.00 @ IJK)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($239.00 @ IJK)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($79.00 @ Shopping Express)
Video Card: Zotac - GeForce GTX 1080 8GB Mini Video Card  ($649.00 @ Scorptec)
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case
Power Supply: Antec - Earthwatts Gold Pro 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($90.00 @ IJK)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($139.00 @ PCCaseGear)
Monitor: Dell - U2515H 25.0" 2560x1440 60Hz Monitor
Total: $2009.20
Generated by PCPartPicker 2018-08-01 13:59 AEST+1000
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11596859
If you're getting a K series cpu for overclocking, you need a Z370 board. The B360 boards aren't for overclocking.
Also get faster memory. 3000Mhz would be good.
https://linustechtips.com/topic/954277-pc-build-help/#findComment-11597011
