Does the H110i v2 have fans come with it? Also do I have to buy thermal paste for my new pc build or do CPU's and AIO come with it pre applied?
        Current PC
CPU: I5-7400
GPU: Gigabyte 1050Ti
RAM: Crucial DDR4 8GB 2133mhz
CASE: GameMax Falcon
MOBO: Prime B250M-A
                                       Peripherals
Mouse: Corsair Sabre
Keyboard: Corsair Strafe
Mic/headphone: Blue Yeti /w JVC HA-SR50X
Mouse Mat: Razer Goliathus
https://linustechtips.com/topic/953834-need-help/
2 minutes ago, Rainbow Dash said:
It comes with two fans, and you need to buy thermal paste with the cooler. I would recommend the Arctic MX-4, since it's cheap and pretty good.
AIOs come with pre applied thermal past, as does pretty much any cooler.
https://linustechtips.com/topic/953834-need-help/#findComment-11590099
It does? My Arctic Cooler Liquid Freezer 240 just came with 2 packs of MX-4. But who knows the pre-applied could be dried up anyways so having extra paste is always a good idea like if they need to remove the cooler to troubleshoot they can at least apply new paste.
https://linustechtips.com/topic/953834-need-help/#findComment-11590107
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590127
@Crunchy Dragon and all I am purchasing a Corsair 400c Case how do you think I should set the fans/AIO (Meaning AIO top or front? I am buying a 1080ti thats pretty bulky and not lite at all.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590132
@Rainbow Dash and @Crunchy Dragon The 2 fans it comes with, are they decent enough to stay on?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590138
1 minute ago, uReqt said:
Well the pre applied paste is fine, but sometimes it's a good idea to just get some thermal paste in case after you installed the cooler and need to remove it cause you installed it the wrong way or something so you can just apply some fresh paste. The MX-2 is a little older paste, but you would rather get the MX-4: https://www.amazon.co.uk/Arctic-MX-4-Compound-Micro-particles-Durability/dp/B0045JCFLY/ref=sr_1_1?s=computers&ie=UTF8&qid=1532927007&sr=1-1&keywords=MX-4
The 2 fans that come with it is decent enough, though they aren't really quiet when you run them at full speed. But they will work fine.
https://linustechtips.com/topic/953834-need-help/#findComment-11590143
@Rainbow Dash how do you control the speed, is it in the Bios or do corsair have software as I'm buying all corsair fans as well
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590147
You plug the fans and pump into the fan headers for the CPU fans and pump on the motherboard and that way you can control the fan and pump speeds. Or you can use the Corsair Link program to control the pump and fans.
https://linustechtips.com/topic/953834-need-help/#findComment-11590156
@Rainbow Dash thanks what about this
Quote
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590160
@Rainbow Dash Can the h100i v2 fit at the front?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590206
@Rainbow Dash With a 1080ti ?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590229
@Rainbow Dash Alright, Thanks for everything.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/953834-need-help/#findComment-11590249
