7 minutes ago, xMystic Horizon said:
is there any possible way i can upgrade my gpu i have  a dell g5 15
what graphics card is in it?
last time i asked this sort of question (about the cpu) i was told it can be quite difficult to do inside of a laptop configuration
https://linustechtips.com/topic/953797-1060-max-q/#findComment-11589776
1 minute ago, t4ils said:
Looks like it has a USB 3.1 and Thunderbolt 3 port, so it's possible. Just need to buy an external GPU enclosure and a better GPU. I'd say the GTX 1060 is already decent though.
i couldn't tell if that is what he wanted to put in the laptop or if that was the one already inside of it
https://linustechtips.com/topic/953797-1060-max-q/#findComment-11589785
Really depends on the CPU. Also, in a dell gaming laptop, how much better does it really get? 1060 is already pretty good, and you'd bump into a thermal limitation sooner or later
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/953797-1060-max-q/#findComment-11589788
The only thing that can upgrade the GPU is by using an eGPU. But you're spending practically the same for another one of those laptops.
Otherwise the GPU is soldered onto the laptop's mainboard, so there's no upgrading it.
https://linustechtips.com/topic/953797-1060-max-q/#findComment-11589837
Not really unless you get one of those external enclosures, but honestly given the performance drop over thunderbolt you're probably best just sticking with your 1060.
Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo
Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo
https://linustechtips.com/topic/953797-1060-max-q/#findComment-11590141
