Hi!
Last year i bought my PC and now im looking to upgrade it piece by piece. I'm not that familiar with building computers so i need help!
I play alot of FPS games such as CSGO, PUBG, Fortnite, Overwatch and WoW occasionally and usually aim to play at high fps with low settings. So basically i just want to increase my framerate and reduce the dips below 144fps.
I was wondering in what order i should start upgrading the pieces and with what parts? Should i change to a Ryzen 7 if i plan on streaming my games occasionally aswell?
Please excuse my stupidity as i really am not familiar with this stuff AT ALL. :)
My specs are:
Case: Bitfenix comrade
GPU: Radeon rx 480 8gb
CPU: AMD Ryzen 5 1400 quad core
RAM: 16gb
Fan: 2x bitfenix spectre 120mm
Memory: 476gb ssd i believe
https://linustechtips.com/topic/953649-need-help-upgrading/
It's a pretty modern PC to me, it looks fine as is! :) You'd feel the most performance jump from going from your RX 480 to an RX 580.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/953649-need-help-upgrading/#findComment-11588407
An OC 480 will feel the same as the 580 as they are the same chip.
Depending on the budget there is no real upgrade id recommend. Id wait untill next year before touching anything. New Nvidia GPUs will have settled in price and new Ryzen 3000 series will offer a more compelling upgrade
Then again: this is mostly down to how much you have to spend on this upgrade
https://linustechtips.com/topic/953649-need-help-upgrading/#findComment-11588440
I'd hold out for 3rd gen Ryzen but if y ou want to upgrade now a Ryzen 7 2700 and a B450 motherboard would be a great option and then you can make the jump to an 1170 or something down the line
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/953649-need-help-upgrading/#findComment-11588475
