I want to create a new system for myself for playing games like league of legends and other games like Starcraft on high or better settings but the problem is I don't know what part will optimize and be in my budget (1000$)
I would like to make this system upgradable for the future.
Please help
https://linustechtips.com/topic/9536-advice-for-a-first-build/
A GTX 650 Ti will handle StarCraft II at max settings with relative ease, pretty much anything will handle league of legends. You should probably look at an i5-3570K on a Z77 motherboard. You might have to go for less though if your budget includes a monitor and a copy of Windows.
https://linustechtips.com/topic/9536-advice-for-a-first-build/#findComment-104310
Just a rough estimate of the highest tier of hardware you can get
You should be able to squeeze it under if you find a decent sale or just drop something to the tier under and even if you do, it will still blow away sc2 and lol at ultra settings
http://pcpartpicker.com/p/PGjE
3770k, Asrock Extreme 4, 16GB Dominator Plat, AX760i, 250GB BX100, 1.5TB Seagate, Win 7 Home Prem
https://linustechtips.com/topic/9536-advice-for-a-first-build/#findComment-104368
the 7770 outperforms the 650 ti in sc2 by a long shot, slick benched it
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/9536-advice-for-a-first-build/#findComment-104377
Cool. I was just giving my experiences with the card I have.
https://linustechtips.com/topic/9536-advice-for-a-first-build/#findComment-104381
Here is a neat & powerful little rig that you can overclock to hell and throw another 7870 in crossfire some time down the road: http://pcpartpicker.com/p/PGAR
Have fun :)
https://linustechtips.com/topic/9536-advice-for-a-first-build/#findComment-104383
