If I am using a Cosair 750D case, using two 140mm Intakes on the front of the case, would using a Cosair H110 as an exhaust be enough airflow for the case as my motherboard won't connect any other fans so I cannot have another exhaust.
I could buy a splitter if I need but would rather not. So would the two intakes and two exhausts running through the radiator be enough for good airflow?
Cheers for any replies.
https://linustechtips.com/topic/95352-optimal-airflow-question/
You have your psu at the bottom I assume it's orientated for intake, and then intake from the front, and exhaust through the rear, this is fine.
Heaven's Society - Like Anime? Check us Out Here!
https://linustechtips.com/topic/95352-optimal-airflow-question/#findComment-1276904
it's ok
positive pressure is good
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/95352-optimal-airflow-question/#findComment-1276917
