Replaced CPU in a laptop, now its throttling at low temps.
Hiho,
I recently upgraded an older Sony Vaio from i5 560m to i7 740qm.
Cpu works, its just 10W higher but Intel XTU says its throttling even though its around 45 or 50c? Also HWMonitor says that CPU is only using 14W of power and its meant to use about 45W at its peak since its a 45W CPU.
I put Thermal Grizzly on it and spread it evenly on the die. GPU and CPU.
GPU is also fine at 48c.
Frequency is stuck at 0.93Ghz
Therefore its not even reaching its base frequency of 1.73Ghz.
I stress tested it in Cinebench R15 and instead of getting around 270 score i got 115 or so.
Laptop does not have a battery, it uses ac adapter.
All settings in windows enabled to performance. In power options appropriate sliders are set to 100% also.
Anything I can do guys?
Main PC:
CPU: Intel Core i9 13900KS (6.1Ghz P-Cores 4.8Ghz E-cores)
CPU Voltage: LLC6 1.525V (real voltage 1.425V + - Temps 85-90 P-Cores, 70-73 E-cores)
Cooled by: Supercool Direct Die
Motherboard: Z790 ASUS Maximus Apex
RAM: GSkill TridentZ 2x24GB DDR5 8400Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: AX211 WiFi 6 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
Laptop: MSI Titan GT77HX V13, RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 128GB of RAM @ 5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 2x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 10TB NVMe in TB4 enclosures (5x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
I'm not specifically familiar with the Sonys, but I know with the Dells, when they are retrofitted with quad core CPU's, the higher spec power supplies (ie: 90W and higher) become mandatory and the firmware will throttle them to avoid power-supply-induced instability when use is attempted with a PSU that cannot be verified as having a high enough rating.
So you'd probably want to research whether that's the case for specifically for the Sonys, and acquire a higher rated power supply adapter accordingly.
Ac adapter is rated at 120w should be fine. However, Intel XTU is showing thermal throttlimg even though temps are low. Thoughts?
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
Does your laptop has a battery?
ThinkPad masterrace
Me thinkpads:
X220, R30, T24, TransNote
6 hours ago, TheNaitsyrk said:
Hiho,
Are you sure the throttling is thermal?
Maybe you should increase the voltage as your new CPU is more power hungry.
  • 2 weeks later...
Fixed, I downloaded "No Throttle" program and I can set multipliers. Works as expected now.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
  • 3 years later...
Hey man! I know this is an old thread but I just did the Exact same upgrade as you to a Dell M4500 and also having the same problem!
What's the software you used and what Multipliers did you set.
@Linus-Sex-Tips
It is best to start a new thread than to restart a 4 year old thread.
For Intel CPUs,  give ThrottleStop a try. Try clearing the BD PROCHOT box if your CPU is stuck at the minimum speed.
Sorry it's been so long and it was an one day project I wouldn't be able to tell you now.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
