So basically I'm building a new pc and I plan to put it on youtube so I want to have everything go smoothly, so I'm wondering what drivers I will need to download.
I'm using an:
Asus ROG Strix Z370-E Motherboard
Intel i7-8700k
EVGA GeForce GTX 1080 ti
ADADA XPG6000 256GB SSD
Seagate Barracuda 3TB HardDrive
I'm planning on doing basic overclocking. If any more parts are needed to be listed feel free to say.
https://linustechtips.com/topic/953102-what-drivers-will-i-need/
you need nVidia drivers from their site or via geforce experience (which they will shove down your throat so why resist) and you'll need to go to the webpage for your motherboard to get those drivers.
Primary PC:
PSU tier list
How many watts do I need?
1 minute ago, BladeEngage said:
I'm planning on trying to make a youtube channel so I thought I would post this, I'm mainly planning on using Twitch so I'm kinda scavenging for stuff.
the real software headaches will come from getting OBS to work right if you're not familiar.
Primary PC:
PSU tier list
2 minutes ago, BladeEngage said:
I have an idea about it, I've used it to screen record a VR project I created in unreal so I had to do some overlay shizz but I got it to work eventually.
make sure to fine tune your bitrate. too high or too low and stream quality will suffer.
Primary PC:
PSU tier list
Just now, BladeEngage said:
I will take that into account, thanks for the tips! Do you have any recommendations on OBS or streaming tutorials?
unfortunately no, I did everything the hard way and figured it out myself.
Primary PC:
PSU tier list
9 minutes ago, BladeEngage said:
Oh okay, do you have Discord? It would make it easier for us to talk. I'll make sure to ask you if I need help!
I'm an ex amateur streamer, you're better off finding someone who knows more than the most basic OBS knowledge. I couldn't even get OBS studio to work.
Primary PC:
PSU tier list
8 hours ago, BladeEngage said:
Is that all?! Wow, I always thought there would be more. Thanks a lot!
There is. Its just that most will rely on Win10 to get drivers sorted. The stuff you will need are chipset, LAN, audio (if you don't USB DAC), wireless (if you plan to use that), SATA (if you use RAID) and Bluetooth (if you use BT). Plus drivers for you mouse, keyboard, webcam etc. which you get from their support pages. Again, Win10 will get most for you, but if your peripherals are older or have utility software (like most gaming mouse have), those you need to install yourself.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Well all that stuff for the motherboard (chipset, etc) would be on the manufacturer's page under "drivers", so yeah, that's all for that, outside peripherals.
Primary PC:
PSU tier list
Mobos site lists drivers that aren't really needed unless setup is someway special. Like VGA driver for iGPU and SATA I already mentioned. Though installing all does no harm, they aren't "needed".
