The PC still boots up and the issue happend while I was in Fortnite playing the sandbox mode for the 2nd time, so the pc already was on for a long time and in the manager i cant see any driver with a yellow ! .The pc  did not overheat,i can see that because the leds on the mb and gpu were green (settinge were that the leds display temps) and green is a good temp.
CPU: i7-8700K@5ghz
Motherboard: ASUS Z370-F Gaming
RAM: 32GB DDR4 3000Mhz Corsair Vengeance
GPU: ASUS ROG STRIX 1080Ti OC
Case: DARK BASE 900
Storage 1.: 2 TB HDD of Toshiba
Storage 2.:  SAMSUNG 860 EVO  250 GB SSD
PSU: 650W Straight Power 11
Display(s): ASUS VX228(H)
Cooling: SILENT LOOP 360
Keyboard: ASUS STRIX FLARE
Mouse:  ASUS ROG GLADIUS 2
Sound: Sennheiser Game Zero
Operating System: Windows 10
https://linustechtips.com/topic/952907-irql_not_less_or_equal/
Rn im doing an advanced memtest with the Windows Tool.
CPU: i7-8700K@5ghz
Case: DARK BASE 900
https://linustechtips.com/topic/952907-irql_not_less_or_equal/#findComment-11581653
I've only ever gotten this stop code due to a bad overclock.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/952907-irql_not_less_or_equal/#findComment-11581713
Ok shall i sent you pictures of ny oc?
CPU: i7-8700K@5ghz
Case: DARK BASE 900
https://linustechtips.com/topic/952907-irql_not_less_or_equal/#findComment-11584036
Edit: i also got today the bluescreen crash with driver_irql_not_less_or_equal
CPU: i7-8700K@5ghz
Case: DARK BASE 900
https://linustechtips.com/topic/952907-irql_not_less_or_equal/#findComment-11584038
Had igpu on, disabled that and i dunno what to do with BCLK amplitude.
And also i changed the Voltage lf the CPU to 1.35 Volt.
CPU: i7-8700K@5ghz
Case: DARK BASE 900
https://linustechtips.com/topic/952907-irql_not_less_or_equal/#findComment-11584054
And thats my Batch:
CPU: i7-8700K@5ghz
Case: DARK BASE 900
https://linustechtips.com/topic/952907-irql_not_less_or_equal/#findComment-11584076
