So I am getting some custom cable and I have some questions.
1. On the Cablemod configurator website, there is only a dual 6+2 pin option which is what I have for my graphics card currently. It looks terrible having the extra pin sticking out like a sour thumb. My question is, can I use an 8 pin pcie cable or do I have to use the dual 6+2 pin. My graphics card is an MSI GTX 1060 Twin Frozr VI.
2. I am really confused on ssd and hard drive cables. I want to get 1 extension cable for a Sata Power cable. Can I connect this sata power cable to a current sata cable and will it be Jolly Fine.
Much Appreciated if you make a configuration list consisting of Non-Custom PSU Cables with a 24 Pin Power cable, a pcie cable for my gpu, and a sata power extension.
Thank you in Advance.
https://linustechtips.com/topic/952710-custom-cable-questions/
