Hello there,
I require the help of people that may have had experience with something similar.
Recently, I bought a used GTX 780, seems to be working, drivers work, display works and test benched it in MSI kombustor... But... As soon as I do anything intensive on it, it will freeze with the colour of whatever was being displayed on screen most. However, naturally, I wanted to test my new GPU after having found out it froze in kombustor. So, I fire up PUBG, it bricks up and freezes and nothing can be done, I had to hard shut down.
The next time I turned on my PC, I get a bunch of white lines appear across my monitor. These lines go away whenever I move my mouse or do something, they come back soon after, I think the GPU has not been damaged in any way but the fact that less power is being given to it might cause this...?
I am not really sure what causes this but I know that until I put a load onto my PC, it's absolutely fine, therefore leading me to believe it is a power supply issue.
My power supply is an Aerocool integrator 600W, this is the minimum required for a GTX 780, plus the amps on the 12v rail is 42a and should be fine, yet I still get this issue. Previously, before PUBG crashed I definitely thought that it's not drivers, but now I think otherwise due to these weird lines.
Before I used my GTX 780 however, I used an HD 5850 1GB and I experienced weird things. In some games, the FPS would start off high and get lower until it hit an average of about 30 FPS, this number was dependent on the game though. This is what also leads me to believe its a power supply issue as I can't think of any other reason it would do this.
Please, if anyone can help me or tell me what is going on then fire away.
Thanks, BP.
IT Manager working in the Education sector.
https://linustechtips.com/topic/952663-dying-power-supply/
4 minutes ago, Brennan_Price said:
Hello there,
Thanks, BP.
The issues you have make me think of a GPU failure, moreso than a PSU failure, if not for the fact that you've had previous problems with another GPU. Can you use Afterburner to check graphs of GPU usage, clock, power, voltage, temp, mem frequency while hitting with a heavy load that gives you issues but does not crash?
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579435
No sorry, I'm at a stage now where windows tells me that the 780 is not working correctly and it gives me error code 43, however this is now either hardware or software, and I reckon its having these issues because the power supply is not outputting enough power. I don't want to install the drivers again as it might crash and corrupt it somehow. I get these white lines across it constantly now, they will still disappear if I move the mouse over them or move a window.
I have tested it with another graphics card but only with ones that use much less power than the 780, so it's hard to say what's the issue...
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579448
Can you try AIDA stress test on the CPU? Or some kind of CPU power intensive stress test, like Prime95 or OCCT? I'd try that to see if that kind of behavior (crashes, artifacts) is indeed related to the PSU's power delivery, as both CPU and GPUs take power from the 12V rail
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579460
I did think of that tbh... Thing is I really don't want to completely injure my components by having it brick up constantly etc... Then again, when I had the GPU on MSI kombustor, it seemed alright until I did other tasks in the background, therefore increasing the power needed for my CPU.
It was only until I loaded up a game did it crash almost instantly. This makes sense to me as it was trying to deliver to both CPU and GPU and not one or the other. I still want to figure out if the lines are from the GPU now or if the poor power delivery is causing it... Yet I have no other PSU's above 600W that I could use, neither do any of my friends as far as I am aware...
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579492
Ok, try this: within the BIOS underclock your CPU a fair bit, it doesn't really matter how much; you could actually just disable turbo boost. What's your CPU btw? Then, in Afterburner, put a -20% power limit on the GPU and check the behavior of the components to games, Kombustor and such
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579507
OK I can try that in the morning, atm I'm getting ready for bed and wanted to kinda ask before I went to bed. I'll report back to you in the morning.
My CPU is a Xeon X5675 and I have 8GB RAM paired with it. 1 SSD, 2 x hdds, a USB C expansion card and some LEDs. I have 5 fans in my case, I should think my 600w should be able to do this fine, even with a 780 but who knows eh.
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579520
Sure, let me know how it goes and I'll reply as soon as I can! As for the peripherals and such you have you're correct, your PSU should be perfectly fine handling those, so I won't even ask you to disconnect some of those, because they probably wouldn't change the results. That Xeon tho! xD 95W TDP, I'm positive you'll see differences by trying to underpower both him and the GPU
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11579545
Yeah I love my x58 Xeon haha. I've tried it, clocked my CPU down to 1200mhz and still no luck, I'm going to try booting with two PSU's now, one for the 780, one for the rest of the system. Hopefully it'll work.
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11580751
Sure, try that; having two PSUs, you could also try replacing  one with the other or switching them when you're trying them both
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11580758
Yeah I'll do that too. Currently I have the secondary psu hooked up to the 780 with no luck on removing the white lines, however the drivers still won't appear. I'm installing the drivers again so they are there at least to see if that makes any difference.
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11580785
Although using the two PSU's, and having no luck switching then round... I'm now testing my ram as it may be this that is causing the artifacts instead. In Windows, I still get error code 43 from the GPU in device manager...  ??
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11580806
Yeah, it could be a RAM issue too: to test it, I suggest Memtest86 or even the Memory diagnostic in Windows
I expected the problem to change at least slightly by using two separate PSUs, but apparently either the problem isn't power correlated, or it's the PSU that powers the CPU that causes the problem
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11580831
Hiya, got my good ol HD 5850 back in my system with my 600W PSU. Everything seems to be fine, for the moment. I will however change my PSU very soon in the future which will probably be when I buy a more powerful GPU too. There were no RAM issues either so I can assume it must be the PSU still as some games still start off with high fps and it gets lower over time... Not sure if a 500W will be adequate for my system but its a decent psu at least as well. Who knows.
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11581951
I don't know what your CPU is, but generally speaking 500W is more than enough. As for the current temporary setup you have, can you stress test it to exclude the CPU as a possible cause of the issue? Just to be sure
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11582072
Oh, I've stress tested my CPU and GPU multiple times on this PSU without any issues, it's just within games where the fps slowly drops. Also, before I go any further, I'd like to say I've already returned the GTX 780 and am currently awaiting refund so everything will be good. I also get paid on Tuesday so that is when I can probably buy a brand new GPU rather than buying used.
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11582090
Awesome! Glad I could help solving the problem xD
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11582105
Aha yeah, thanks for the help, it's a shame I couldn't get anywhere with your suggested methods but it's given me an urge to buy brand new now, plus to get a much better power supply. I'll buy 80+ gold or platinum next time to go with something such as an RX 570 or GTX 1060. Cheers once again, I'm sure I'll let the forum know about my purchases very soon, I get paid on Tuesday so very soon haha :)
https://linustechtips.com/topic/952663-dying-power-supply/#findComment-11582543
