So i recently got a laptop and it seems to run minecraft at between 40 and 60 fps was between 30 and 50 but then I upped the max fps from 60 to 100 which seemed to increase it by a bit but further changes seems to do nothing
the laptop runs Arma 3 at 60 fps rarely touching 50 fps at 1080p with ultra settings so i don't understand why it cannot do Minecraft at a steady 60fps. so i was after ideas to fix this unless it is the way the game runs
Laptop specs i5 7300HQ, 8GB Ram, 3GB GTX1060, windows 10 with a 1080p display
https://linustechtips.com/topic/952375-minecraft-issues/
What settings are you running it at.
You sure its using the 1060 and not the Intel gpu.
Throttling?
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/952375-minecraft-issues/#findComment-11576668
Throttling?
im sure its using the gpu, it took me ages to work out how to disable the iGPU
running at 1080p @ 60fps, graphics is set to fast, render distance is 12 chunks, clouds is off particles decreased and fullscreen is on, everything else is on default
https://linustechtips.com/topic/952375-minecraft-issues/#findComment-11576676
Throttling?
might be cpu throttling, running minecraft then showed a cpu usage of 80+%, is there any settings that lower the cpu usage?
https://linustechtips.com/topic/952375-minecraft-issues/#findComment-11576678
Hmm, yea you should be able to get easily above 60fps.
But, You should Run minecraft, And open Task manager and see what is running, I also got a new laptop, While Overwatch was using the GPU in my laptop, When I played GTA5, It was auto set to the iGPU, Its a simple check You should see.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/952375-minecraft-issues/#findComment-11576679
Most every laptop Benefits from Undervolting.
With my laptop temps droping 10/15C under gaming, And it is easy to do.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/952375-minecraft-issues/#findComment-11576682
6 minutes ago, WickedStarfish said:
how does one do that? in the bios?
No, Open Minecraft, Go into a Game or A Server,
CTRL + ALT + DELETE , Click Task Manager, Then click "More Details" at the bottom Left , Then go to the Preformance Tab at the top and on the left side, You might have to scroll down, But it should say GPU 1 "NVIDIA GeForce GTX 1060" and it should be at a usage %.
If the Intel GPU is under Load that means you need to switch the Usage to the 1060.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
https://linustechtips.com/topic/952375-minecraft-issues/#findComment-11576694
