Help with adding network drive!!!
Go to solution Solved by Ja55ie,
SOLVED!
answer here! Had to turn the file sharing Windows feature on.
Hello,
I currently have a USB drive plugged into my router and I am able to view the USB and it's content on the network on my two laptops but I can't connect to the drive on my Desktop. I have no clue what the issue is, can someone help me!?
I used the exact same method of connecting to the drive as I used in my laptops but I still can't connect. I used my desktop's LAN and wifi and both didn't work. I recently upgraded my motherboard on my Desktop and I was able to connect to the drive on my old motherboard but it seems to not work on my new motherboard.
HELP!11!11
| CPU: AMD Ryzen 7 5800X | Motherboard: MSI MPG X570 GAMING PLUS | CPU Cooler: MSI MAG CORELIQUID 240R
 | GPU: MSI 3080 Ti VENTUS 3X 10G OC | | RAM: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 | PSU: MSI MPG A750GF Gold Fully-Modular | Mouse: MSI CLUTCH GM50 | Keyboard: MSI Vigor GK60 Cherry MX Red |
| Headset: MSI DS502 GAMING Headset | Case: MSI MPG SEKIRA 100R |
| Displays: AOC AGONAG241QX Gaming Monitor 24" & Acer CB282K 28.0" 2160p 60Hz HDR IPS | Wrist Rest: MSI Vigor WR01 Wrist  Rest |
https://linustechtips.com/topic/952255-help-with-adding-network-drive/
SOLVED!
