Splitter for USB
Go to solution Solved by tzxazrael,
that isn't what a splitter does. it takes one input and "splits" it into 2 (or several).
that would probably be called a "usb switch" but i'm not sure such a thing exists, or even if USB can work that way.
Ty for the help, search for usb switch and its come up with the exact thing I need.
https://linustechtips.com/topic/952173-splitter-for-usb/#findComment-11574698
