Personally I don't think your SSD is worth dropping to 8GB of RAM. Some newer games like the Witcher 3, Rise of the Tomb Raider, Arma 3, ect. all run better with more RAM. If you really want to keep the SSD I suggest swapping out the 1 8GB stick for a 2x4GB stick so you can run in dual channel and add another 2x4GB stick later. I personally still run HDDs and the time it takes me to boot up is not bad at all. As long as you manage your start up programs and enable fast boot in your BIOS setting your boot times should be pretty good.
Edit: considering your also not running a "K" processor you don't need a fan either.
CPU: Intel - Core i5-8600 3.1GHz 6-Core Processor  ($305.00 @ AX86 Gaming Systems)
Motherboard: Gigabyte - B360 AORUS GAMING 3 ATX LGA1151 Motherboard  ($154.00 @ Shopping Express)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($264.00 @ Shopping Express)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($79.00 @ Shopping Express)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Strix Video Card  ($469.00 @ Umart)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($99.00 @ Scorptec)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.00 @ Shopping Express)
Total: $1459.00
Generated by PCPartPicker 2018-07-25 16:41 AEST+1000
21 minutes ago, RAM555789 said:
Fixed everything
dunno where you budget went
Ryzen 5 2600 is a better value
RX 570 at that price is a WAY better value
Should buy a case that actually has airflow as well.
Just gotta find that motherboard, it's the best value choice IMO, probably $100-120 in AUD maybe? If the price is crazy just get the B350 version
Or get like the ASrock Gaming X X370 board given X470's crazy pricing, but it may need a BIOS update
https://au.pcpartpicker.com/product/h8DzK8/asrock-x370-gaming-x-atx-am4-motherboard-x370-gaming-x
PCPartPicker part list: https://au.pcpartpicker.com/list/vFqCD2
Price breakdown by merchant: https://au.pcpartpicker.com/list/vFqCD2/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($244.00 @ Shopping Express)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($239.00 @ IJK)
Storage: Western Digital - Green 240GB M.2-2280 Solid State Drive  ($68.00 @ Centre Com)
Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card  ($249.00 @ Amazon Australia)
Case: Cooler Master - N300 ATX Mid Tower Case  ($58.00 @ Skycomp Technology)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($105.00 @ Shopping Express)
Total: $1042.00 +$100-120
Generated by PCPartPicker 2018-07-25 16:58 AEST+1000
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($258.00 @ Shopping Express)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($102.51 @ Amazon Australia)
Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive  ($95.00 @ Umart)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card  ($389.00 @ Shopping Express)
Case: Thermaltake - Versa H18 MicroATX Mini Tower Case  ($49.00 @ BudgetPC)
Power Supply: Antec - Earthwatts Gold Pro 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($90.00 @ IJK)
Total: $1301.51
Generated by PCPartPicker 2018-07-25 20:19 AEST+1000
