So I need some help on part picking . . .
My current build contains:
an i5 2600 scavenged off of my dad's workstation
an unnamed Intel motherboard I found in an old gaming pc containing an i3 2100, I then replaced the i3 with the i5.
8gb of Corsair ddr3 ram 1600ghz 2x4  (also found in old gaming pc).
750w corsair atx power supply non-modular.
Stock Intel Cooler.
I then received an MSI GTX 1080 11gb GAMING X for Christmas :)
I then bought a SilverStone Primera rgb matte black.
A 2tb Seagate firecuda hard drive.
A 128gb Silicon Power SSD
I have the plan of having an i7 8700k but I do not know what cooler I should use. I am looking for an Aio....preferably Rgb with overclockability. I am also planning to use the MSI Z370 Carbon Pro. Lastly for ram i would to get the trident Z RGB if my budget allows.
All very expensive but I have a job(I am less than 16) and currently (due to good grades) I have 300 dollars to spend. What should I buy first?
I am new to this Forum even though I am a long time Linus Fan. \
Thanks for your Help!
https://linustechtips.com/topic/950992-help-on-my-build/
welcome to the linus Tech Tips forums!
the 2600 is actually an i7-2600 (4cores/4threads - hyperthreading) the i5 was an i5-2500
going to the 6/7/8th GEN will require different RAM as they are on DDR4, you're still on DDR3. so your task just got more expensive.
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563515
Thank you so much for your response. I am aware of the ram change would be expensive and whoops my bad on the CPU mess up. Personally . . . what Ram do you run/use?
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563533
Stock Intel Cooler.
300$ cant get you a 8700k. might i suggest you tone it down a little bit with a 8350k?
i have 16gb of the cheapest ram at my local Micro center, in this case 2x8 crucial ballistix sport ddr4-2400
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563534
Would an i3 8350k be able to run a triple monitor set up (future goals) and be able to fit inside of the motherboard I would like to buy? ( MSI Z370 Carbon Pro)
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563539
yes, thats dependent on the GPU, and yes. it has 4c/4t so its basically a 7600k and in the future you can upgrade to the new intel 9th gen.
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563542
So my MSI GTX 1080 11gb GAMING X is powerful enough for a triple monitor set up? Is there a same price Ryzen equivalent since there is an AMD version of the motherboard.
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563576
a ryzen 5 1500x should be fine for gaming, a 2600x is also good.
https://linustechtips.com/topic/950992-help-on-my-build/#findComment-11563579
