saw this add for CAD600 is it worth it if yes what should i look for ..
Little used mid-range DSLR with only 7072 actuations. Bought as a replacement for a D5200 that I thought I had lost, which I found 2 years later, and then sold. My interest in photography has waned, thus the sale. THE PRICE IS FIRM UNLESS YOU CAN JUSTIFY WHY IT IS NOT APPROPRIATE. Please do not ask to buy individual components.
Included are:
Nikon D5200 body with only 7072 actuations (it's tested to 100,000)
Sigma 18-200 mm optically stabilized lens
Nikon DX VR 18-55 lens with UV filter
Nikon DX 50 mm lens with UV filter
Nikon DX 35 mm lens with UV filter
Nikon MH-24 wall charger with 2 batteries
Nikon EH-68P outlet to camera charger
Nikon HB-47 hood
Nikon HB-46 hood
Nikon ML-L3 remote control
Lowe pro camera bag
Nikon soft sacks (2) for 50 and 35 mm lenses
https://linustechtips.com/topic/950804-used-equipment-help/
Included are:
Nikon HB-47 hood
Nikon HB-46 hood
Lowe pro camera bag
whats the price new? look for any scratches on the lens, test it out to see any imperfections, then if you really want it and its a good deal, buy it
https://linustechtips.com/topic/950804-used-equipment-help/#findComment-11562023
lenses are approx 250 other two primes are 200 each and kit lens  18 to 55 is approx 100 used
https://linustechtips.com/topic/950804-used-equipment-help/#findComment-11562027
