Usually I see recommendations to clean out a custom loop every 6 months or so.
https://linustechtips.com/topic/950671-replacing-coolant/#findComment-11560724
2 minutes ago, Livesundersink said:
can you link me to a tutorial or guide on how to drain the system properly?
https://linustechtips.com/topic/950671-replacing-coolant/#findComment-11560733
3 hours ago, Livesundersink said:
I am in the process of putting a new build together, this build will include a custom watercooling loop, i have seen in a number of posts that i should replace the coolant at regular intervals, i was wondering how often these intervals should be
largely depends on the coolant you use. Every year would be very safe for rhe modern non-opaque coolant like EK cryofuel, they can probably even go longer.
https://linustechtips.com/topic/950671-replacing-coolant/#findComment-11561080
