Hey everyone,
I was wondering if it would be possible to cool a computer by using an air conditioner, or something of the sort.
You can have a huge fan running outside your home, with tubes running all the way to your computer.
You wouldn't have any fan noise, as it will be outside, and you can have big powerful fans instead of the usual smaller ones.
What do you think?
https://linustechtips.com/topic/950419-utlimate-computer-cooling/
You probably could, I'd duct tape one of those long dryer vent tubes to the AC and then attach that to one of the case fan spots, or maybe right to the CPU heatsink. I've thought about doing it for no reason other than fun once but didn't have an AC or dryer vents
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
Whatever you do, don't do what the above says. It'll cause massive corrosion inside your system with all of the condensation.
Other PC based YouTube channels have done this, by blowing an AC across a water cooling radiator, and it works.  It's just not necessarily efficient in any way.
My favorite one was when a Scandinavian YouTuber put his PC out in the freezing snow and ran the cables through his window.
thanks, I was actually legitimately going to try it until I read this.
If you want to use AC, have it blow across the radiators. It cools the effected components, especially if you have a monoblock to cool vrm as well as the CPU.
I've been wanting to do a rig using a loop connected to a car radiator, then blow an AC through the radiator and see how well that would work
Simply running your radiator in a separate room is much more logical, as @Evanair was saying condensation is a real issue with sub ambient temperatures.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
