18 minutes ago, ImHKpeople said:
Are you recording to an SSD?
I'm totally out of ideas, maybe try the OBS forums.
Just now, ImHKpeople said:
yea its in ssd , i'll try to reset my pc and wipe out all the things then tell u how it turns out
More than likely there's just some obscure setting that's putting too much stress on the encoding if anything.
6 hours ago, ImHKpeople said:
actually , i havent install my chipset drivers yet , anything to do with that?
Probably not, your cinebench score is fine.
well , thanks for the useful help , so i installed a fresh new windows 10 even tho i have to figure out how to fix that stupid bug that says errors occurred when resetting your pc , no changes were made bug , after 5 hours of trying i used the mediacreation tool and installed it to my usb then install windows then format my drives and it finally worked so does the stream , super smooth at 1080P 60fps medium cpu preset
6 minutes ago, ImHKpeople said:
Maybe it was some strange issue/conflict with the windows install then
as always the quickest solution to software issues was just reinstalling windows I guess.
yea but pretty annoying tbh i need to reinstall everything again
ty for the help dude
