SpeedFan or turn them down in bios. I have set all my fan to lowest settings via bios and only ramps to highest at full load.
Magical Pineapples
https://linustechtips.com/topic/950260-loud-fans/#findComment-11557329
What motherboard do you have? Are you using 3pin or 4pin SP120's?
https://linustechtips.com/topic/950260-loud-fans/#findComment-11557333
6 minutes ago, zoodoo123 said:
I turned them down all the way in bios but it didn’t work.
You sure you save setting and also we need more information like motherboard and if it PWM or DC (3 or 4pin).
edit: Also speed fan works, just look for tuts on youtube by jayz2cent.
Magical Pineapples
https://linustechtips.com/topic/950260-loud-fans/#findComment-11557348
2 minutes ago, zoodoo123 said:
Motherboard is the z370 hd3 and its 3 pin
Have you plugged in the internal usb 2.0 header and used NZXT's CAM software?
https://linustechtips.com/topic/950260-loud-fans/#findComment-11557355
5 minutes ago, zoodoo123 said:
Yeah I tried both, it didn’t work.
Have you set the fan headers to Voltage mode instead of PWM in the motherboard settings?
https://linustechtips.com/topic/950260-loud-fans/#findComment-11557385
