Newbie's first build
42 minutes ago, Sb2333 said:...
the X470 motherboard I selected is a bit over my budget, and I know that B350 needs BIOS update and B450 ain't out yet. But do I have any other option that could save me some money? Is the BIOS update complicated to do?
If possible, I would like to shave another 50-100 off my estimated price. What can I do? Ex. a cheaper(without losing too much quality) power supply or cheaper fans?
mid tower size is kinda big, and since I don't need an optical drive or hdd, can I go with a smaller case?
when do parts usually go on sale?
Anything I need to keep in mind?
- BIOS updates are not that difficult. However, (with the exception of some Asus motherboards), one needs a cpu that works with the old BIOS to do the update. Most motherboard manufacturers released updated BIOS at the end of January. As a general rule newly manufactured motherboards have the latest BIOS. But if one does get an incompatible BIOS AMD has a solution, see https://support.amd.com/en-us/kb-articles/Pages/2Gen-Ryzen-AM4-System-Bootup.aspx.
- Drop 2 of the fans. Pick a less expensive ssd, Western Digital - Blue 500GB 2.5" Solid State Drive or something even less expensive. Get a slightly less expensive gpu, MSI - GeForce GTX 1070 8GB Video Card. Get a slightly lower capacity psu, still more than enough for the build, Rosewill - Capstone 550W 80+ Gold Certified Semi-Modular ATX Power Supply.
- I'm not aware of any mATX X470 motherboards so mATX cases are out. There are mini-ITX motherboards but they and mini-ITX cases are out of budget. There may be smaller mid-Tower cases, but they would also be out of budget.
- Thanksgiving both Canadian and US are usual times.
- Faster memory really helps Ryzen cpu.
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor ($244.99 @ Memory Express)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard ($172.75 @ Vuugo)
Memory: Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory ($186.33 @ Amazon Canada)
Storage: Western Digital - Blue 500GB 2.5" Solid State Drive ($125.75 @ shopRBC)
Video Card: MSI - GeForce GTX 1070 8GB Video Card ($529.99 @ Amazon Canada)
Case: Cougar - MX330 ATX Mid Tower Case ($54.95 @ Vuugo)
Power Supply: Rosewill - Capstone 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($79.99 @ Newegg Canada)
Case Fan: Cooler Master - SickleFlow (Red) 69.7 CFM 120mm Fan ($9.75 @ Vuugo)
Total: $1404.50
Generated by PCPartPicker 2018-07-20 21:56 EDT-0400
