discord Help required
Solved by tallejos0012,
Create a number with google voice and then set the number you created to discord google voice does talk and text and reply back if this solved your problem for my sanity
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
