So I bought an used motherboard with an i7 2600k included for 100$, I don't get it to work, it starts then shortly after turns off and it does this 3 times before fully turning on, tried different ram ports, different ram, I have cleaned the ram n ports, but the problem is that I get no picture, tried 3 gpus, I'm using an 850w bronze psu. Is the motherboard broken?? The i7 works great on my other lga 1155 motherboard, and yes I've tried the other pcie slot.. :(
Tried resetting cmos too..
All power connectors is seatted properly too.
You can see the video (bad quality cuz max size on the video could only be 20mb)
20180720_173730.mp4
https://linustechtips.com/topic/950014-motherboard-problem-help/
