What would you go for
I9 7900x
Hx1200w or axi 1200
Gigabyte aourus x299
Or
Amd tr 1920x
Hx1200w or axi 1200
And x399 aorus or msi board
computer used for rendering,servers, virtual machines ,3d modelling and game engines,editing
just need to pick motherbaord, power supply and processor
any input would be greatly appreciated.
Thank you
https://linustechtips.com/topic/949681-pc-build-help/
If thats what you're doing with the machine you'd benefit more from a dual or quad socket xeon system , the i9 or 1920x isn't going to be quite as fast at those tasks as a distributed load will. Essentially there's no reason to use consumer hardware here.
https://linustechtips.com/topic/949681-pc-build-help/#findComment-11552699
i9
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/949681-pc-build-help/#findComment-11552700
I would go for the Threadipper build; Core i9 stuff can get excessively hot compared to the Threadipper which is comparably more stable from what I've seen through YouTube reviews.
Furthermore, X399 Aorus and AX1200 PSU.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/949681-pc-build-help/#findComment-11552703
