CREATE TABLE artists (
    id INTEGER PRIMARY KEY AUTOINCREMENT,
    name TEXT,
    country TEXT,
    genre TEXT);
INSERT INTO artists (name, country, genre)
    VALUES ("Taylor Swift", "US", "Pop");
    VALUES ("Led Zeppelin", "US", "Hard rock");
    VALUES ("ABBA", "Sweden", "Disco");
    VALUES ("Queen", "UK", "Rock");
    VALUES ("Celine Dion", "Canada", "Pop");
    VALUES ("Meatloaf", "US", "Hard rock");
    VALUES ("Garth Brooks", "US", "Country");
    VALUES ("Shania Twain", "Canada", "Country");
    VALUES ("Rihanna", "US", "Pop");
    VALUES ("Guns N' Roses", "US", "Hard rock");
    VALUES ("Gloria Estefan", "US", "Pop");
    VALUES ("Bob Marley", "Jamaica", "Reggae");
CREATE TABLE songs (
    artist TEXT,
    title TEXT);
INSERT INTO songs (artist, title)
    VALUES ("Taylor Swift", "Shake it off");
    VALUES ("Rihanna", "Stay");
    VALUES ("Celine Dion", "My heart will go on");
    VALUES ("Celine Dion", "A new day has come");
    VALUES ("Shania Twain", "Party for two");
    VALUES ("Gloria Estefan", "Conga");
    VALUES ("Led Zeppelin", "Stairway to heaven");
    VALUES ("ABBA", "Mamma mia");
    VALUES ("Queen", "Bicycle Race");
    VALUES ("Queen", "Bohemian Rhapsody");
    VALUES ("Guns N' Roses", "Don't cry");
SELECT title FROM songs WHERE artist = "Queen";
SELECT name FROM artists WHERE genre = "Pop";
/*add another query that will select the title of all the songs from the 'Pop' artists. It should use IN on a nested subquery that's based on your previous query.*/
/*select title from songs where genre in artists = "Pop"*/
SELECT title FROM songs WHERE name IN (SELECT name FROM artists WHERE genre = "Pop");
I have no idea how to do this. Someone help/??
If it is not broken, let's fix till it is.
https://linustechtips.com/topic/949539-sql-sub-querry-question/
4 minutes ago, ZeouLs said:
@mrchow19910319 what exactly do you need help with`? o.ô
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11551293
SELECT title
FROM songs s
INNER JOIN artists a ON (s.id = a.id)
WHERE genre = 'Pop'
let me know if you need help for understanding it
EDIT: you could also change the INNER JOIN with a LEFT OUTER JOIN which in many cases yields more results
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11551317
6 minutes ago, ZeouLs said:
SELECT title
FROM songs s
WHERE genre = 'Pop'
okay.. I only know:
WHERE
IN
SELECT
INSERT
syntax...
care to explain???
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11551332
SELECT title --> takes alles the data from the column title
FROM songs s --> choose in which table our selected column is in. in this case it's songs and I give it the alias s to make it less to type if I need it again (plot twist, we do)
INNER JOIN artists --> inner join is a way to combine two tables with each other (at the bottom is a picture with all the methods for a join), so if you type inner join artists it will combine songs with artists. in order for it to work you need to match the id's which leads us to
ON (s.id = a.id) --> first of all s.id is the column id from the table songs and a.id is the column id from the table artists. remember when I said I gave them an alias cause it's less to type? the s.id stands for songs.id and a.id for artists.id. What happens here is I take the id from one table and combine the other table for values where both of the ID's match.
WHERE a.genre = 'Pop' --> I actually forgot to put 'a.' infront of genre, this might cause issues when tables have the same name for columns. What happens here is I filter all values for their genre. Everything that isnt the genre Pop wont be listed
check out https://www.w3schools.com/sql/default.asp
They have very good examples and tutorials you can do
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11551374
3 minutes ago, ZeouLs said:
I will take a look at this tmr... too tired just got off from work and learned a bit about SQL for 2 hours. I will give you a reply tomorrow.
also I am following this tutorial, what do you tthink about it?
do you think that it is good for a beginner?
https://www.khanacademy.org/computing/computer-programming/sql
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11551391
Never used but seems like a good source to learn
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11554097
On 7/19/2018 at 3:49 PM, ZeouLs said:
SELECT title
FROM songs s
WHERE genre = 'Pop'
The assignment is to use a subquery, not a join (which I personally would prefer as well).
However, with the schema the OP has given, this can't be solved. There is no association between songs and artists as it stands.
But assuming song.artist is a foreign key referencing artist.name (which I would strongly discourage, as you usually really only should create foreign keys referencing primary keys):
select	title
from 	song
where 	artist in (
  			select name
  			from artist
  			where genre = 'Pop'
https://linustechtips.com/topic/949539-sql-sub-querry-question/#findComment-11559737
